I recently was given a 9" rear end complete from a 1976 F150/250 truck.
It doesn't seem to be in too bad of shape. I was informed that I'll have to have the spring perches and or the shock mounts relocated. I found both sets on Jeff's Bronco Graveyard for less than $40 total. Narry an issue with that piece.
The one question I have however, correct me if I'm wrong, I should be able to remove the 3rd member, refill it with fluid and be done, right? Clean it up with carb cleaner, let it dry and check the teeth (et al) for excessive wear or damage and if there is none, be done.
How can I check to see what the gear ratio is - would it be stamped on the carrier or somewhere?
I also want to sand it down, repaint the entire rearend, replace the brake drums and shoes and install new U-joints on the drive line while I'm under there.
I appreciate all of your input, and look forward to seeing what you all have to say!
