Bassani X pipe
310 views 15 replies 4 participants last post by  JERKYBOYXIII
#1 ·
I got lucky enough to buy a Bassani X pipe and pair it with the matching equal length shorty headers. I was rolling underneath yesterday and noticed the crossover pipe from the drivers side to passengers side is lightly touching my bell housing. Any thoughts on a fix?
#2 ·
X pipe or Y pipe?
owns 1991 Ford Bronco Eddie Bauer
#3 · (Edited)
Your original post sounds confusing, but if you loosen the bolts to your header flanges you might be able to move the exhaust enough to clear your bell housing with a pry bar or similar.
Reactions: JERKYBOYXIII
#4 ·
You can dimple the pipe if need be. Engine masters did a test years ago where they dyno'ed an engine and then took the headers off and beat the hell out of them with a hammer, it lost virtually no power and the AFR hardly changed either.
#13 ·
There have been multiple tests comparing Single and Dual exhaust set-ups on our vehicles and the correctly sized Single exhaust out flowed a correctly sized Dual exhaust in Torque and HP, just throwing it out there for Informative purposes only!!!! What you presented though was a Uniquely designed Dual set-up!
#14 · (Edited)
Im definitely impressed w my setup. Bassani equal length shortys and the x-pipe, gibson stainless di/do 3" chambered x muffler dumped just behind the cab. My .530 lift, 262/270 duration cam makes that setup sing!
I have a dual setup on my 94 that breathes through the same x muffler, but it's limited by the stock cam. I will hafta take a pic and post back here someday.
