I recently have been having a problem on cold days (below 40 or so) with the bronco sputtering and knocking on startup after sitting overnight. come to think of it.. the longer it sits the more chances i have of it sputtering and knocking...
when i turn the key it begins to start, however doesn't fire right up, instead it makes a chugging/knocking sound like its misfiring or mistimed for a few seconds then will either start running or die. If it dies, i can restart it no problem most of the time, although today it required 2 starts to get it going. Last night was 17F here, so pretty cold...
once it has been started it will run fine, same goes for warm days about above 50-60F...
My first thought is fuel pump, but not sure.. still doing searches on here but thought i would post up as well.
A little more info:
I did the 6 liter tune up last year, was timed at 14, but backed it down to 11 - 12 a few weeks ago.
No other problems with the engine that I know of, no leaks, just went through all the fluids and changed oil less then 2 weeks ago.
Radiator was replaced in July so new fluid there.
Seafoamed it 3 weeks ago.
Battery is a heavy duty one, less then 6 months old, but not saying it can't be bad...
The starting problem has been going on for about 3 months now off and on...
A little more info:
