yo;
to help out with electrical end here is the Wiring Diagrams in an 89 5.0, 5.8 & 7.5
Source: by Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums
see that EEC relay too?
Fusible Link A-Brown 18ga to Rear Window Defroster; W-Blue 20g to Fuel Pump Relay; N-Blue 20g to EEC Power Relay; F-Blue 20ga to Trailer; Y-Blue 20ga to N.C.; L-Brown 18ga to ?; M-Brown 18ga to ?;G-Blue 20g to Exterior Lamps, Trailer; P-Blue 20ga to ?; & J-Green 14ga to Alternator as shown in Wiring Diagram in an 89
Source: by Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums========
87-89; Fuel Injected Engines - "...
Two electric pumps are used on fuel injected models; a low pressure boost pump mounted in the fuel tank and a high pressure pump mounted on the vehicle frame. The low pressure pump is used to provide pressurized fuel to the inlet of the high pressure pump and helps prevent noise and heating problems. The externally mounted high pressure pump is capable of supplying 15.9 gallons of fuel an hour. System pressure is controlled by a pressure regulator mounted on the engine
Low-Pressure In-Tank Fuel Pump for '84-89 EFIs
The fuel pump is a motor with an impeller assembly, much like an oil pump, so it will allow fuel to leak backward into the tank when it's not running. This behavior is VITAL to the operation of the dual-function reservoir. Inexpensive aftermarket solenoid-stlye fuel pumps do not allow fuel to leak backward, and so inhibit the DFR. by Ford via Steve83
Pump, Filter, & Single-Function Reservoir Parts Break-Out Diagram in 84-89
FP Test & Diagram at the Diagnostic Link Connector in 84-95; "...Connect FP Relay to any ground to force the fuel pump(s) on when the key is in RUN..."
http://www.supermotors.net/registry/media/245234
Operational Sequence; "... When the ignition switch is ON, it turns the EEC power relay ON. The EEC power relay provides power to the powertrain control module (PCM) and the control side of the fuel pump relay.
Power for the fuel pump(s) is supplied through a fuse link or high current fuse attached to the starter solenoid (battery side). From the fuse link or high current fuse, current flows through the fuel pump relay and inertia switch to the fuel pump(s).
When the ignition switch is turned ON, the fuel pump(s) will operate. If the ignition switch is not turned to the START position the PCM will shut the fuel pump(s) OFF after 1 second. The PCM will operate the fuel pump(s) when the ignition switch is turn to START position to provide fuel while cranking. After the engine starts, the PCM will continue to operate the fuel pump(s) unless the engine stops, drops below 120 rpm or the inertia switch is tripped
The inertia switch is located in the cab, generally under the dashboard on the right side; or behind parking brake assy. It is designed to open the fuel pump power circuit in the event of a collision. The switch is reset by pushing each of 2 buttons on the switch simultaneously (some models use switches with only one reset button). The inertia switch should not be reset until the fuel system has been inspected for damage or leaks." (under license from Delmar Publishers, combo of Chilton/Nichols/Delmar & Haynes); some may be incorrect, as reported by Seabronc, thanks Seabronc! NEW SITE URL!!! MUST REGISTER TO VIEW; select year, make, model, engine size and go to appropriate section
Source: by Chilton via AutoZone
