Hi all,
The past 2 days Ive been doing as much reading as possible (until you just cant read anymore:banghead ) trying to figure out why my bko is sputtering. I am trying to make up a checklist for my next day off to narrow things down. Any help would be great. Here are the specs
93 Bronco 5.8
Fresh 351w
All new silicone vacuum lines
Reman Ford fuel injectors - the ones for the explorer (orange/yellow) 4 hole
Ford Racing Plug Wires
Motorcraft basic plugs
MSD Ignition
Issue - Truck fires right up no problem. At operating temp, when i rev it, it doesn't quite have the throttle response it should. It doesnt sputter when parked and under throttle. Its just not all there. Also doesn't seem "smooth". Similar to if its not firing on all 8 but i don't think its that. So... ok.. lets take it for a drive. Once in gear, and under load, the truck sputters pretty bad. It doesn't do it at idle. It idles fairly well but not as smooth as Im used to. I take it down the road and there is no torque, no pep. Sputtering like crazy.
So... this is what Ive come up with to check next time:
Check plugs and compression
Check wires
Check Fuel pressure (never done it)
Check Timing (10 BTC)
If all of these test fine, im guessing maybe my injectors might not all be working properly? i do have the originals which weren't bad but they've been sitting on my bench for some time now. Id hate to have to pull the upper manifold again :banghead
Any help or thoughts would be great
Thanks
Tim
93 Bronco 5.8
Fresh 351w
MSD Ignition
Check wires
Thanks
Tim
