rear sway bar install
1 reading
730 views 4 replies 3 participants last post by  Sven.dk
#1 ·
Hi
After changing bushings on the rear sway bar on a 1978 Bronco How do i installe the sway bar in the correct position on the aksel? the sway bar is atached with u bolts and can rotate on the aksel!
Thanks
#2 ·
Need to put it in a position so it will clear the rear diff. For me with a larger D60, it was at this position.
When you tighten U-bolts against axle, they will stay in place.
My sway bar may have been off a 3/4 ton truck, I forget at this point.
But the advice above still applies.
Reactions: Sven.dk
#4 ·
This is where mine was on my 78 before I removed it. It's a factory suspension, so no lift or anything like that.
