Yo,
This didn't make my reply ;
A neat mod by jrichker; "...Put the resistor inside the heat shrink tubing and crimp the connectors on. I would choose the Ford pin connectors since they should plug in the TAB & TAD wiring. That way you haven't modified the wiring so it is easy to re-install the TAB & TAD solenoids if emissions testing comes to your area. 18 gauge crimp on taps..."
read more and see many pics.
at
Are the TAD/TAB vacuum solenoids NEEDED?
EGR Eliminator Installation Manual by Ryan M. @
Wayback Machine
EGR Do it yourself MIL Eliminator by TrimDip @
Ford Mustang Forums
miesk5 Note, see EVP pins by SeattleFSB @
EGR Valve Position (EVP) Sensor Testing & Replacement
"And, I did find this, "here's an even easier way; once the EGR valve is removed off the car, remove 3 small (7mm?) screws to disassemble the pintle assembly (EVP) from the EGR valve body. plug the EVP back into the wiring harness and push the steel pintle in about halfway and using strong tape (green or red duct tape works best), wrap the tape over the pintle so that it holds its halfway-in position. hide the pintle assembly out of sight. I've run my car like this for at least 5 months now and no check engine light. No soldering needed, no money spent except if you need to buy tape and its still safe and reliable. just remember to put an EGR delete plate over the opening in the upper intake, a cap over the heater tube opening on the passenger side header and plug off your 2 or 3 (now disconnected) vacuum lines." by cobraman1024 @
Ford Mustang Forums
EGR Location & Block-Off Plate pic in an 89 @
https://www.supermotors.net/getfile/439467/fullsize/dsc02766.jpg
Source: by Tim C (TnTbronco2, Trail Truck, Street Truck, Crazed, Broke, OoG)
Here is Ryan M's now closed parts site @
RJM Injection Tech ? Welcome
Ryan also sold;
Actuator Eliminator Resistor $2.00 each
75 ohm 3watt Resistors can also be used to eliminate the EVR, CANP, TAB & TAD solenoids.
