Edit: See solutions in following posts.
Hello. Summary: I have a 1996 Bronco 5.8 with a rebuilt E4OD leaking from the front bellhousing. The leak is a constant dripping and occurs after 10-15 seconds on start-up.
Backstory:
I have taken out the transmission TWICE. First time, I replaced the torque converter, pump seals, o-ring, gasket, bushings, viton front seal, etc.
Transmission still leaked.
The second time, I fully rebuilt the entire transmission front to back (burned clutches and such). Still same torque converter though. Took about two weeks but I feel pretty good about it. However, I installed it today and it still leaks from the front, quite steadily. :/
I would like any help or experience with this. I assume I will have to take it out again much to my chagrin, and maybe find a cracked torque converter snout or pump body damaged/cracked? Is this something anyone else has experienced? I'm just not that familiar with hard parts like torque converters or pumps cracking...
But...Could a clogged transmission line cause front seal leakage? Or, wouldn't fluid exit out the path of least resistance, the vent? I would love to avoid removing this darn transmission for the third time.
I'm in deep on this Bronco and frankly feeling pretty down. Thanks all.
Backstory:
