I posted about this a few years ago, never got any answers. Figure I'll repost it and try again.
My Bronco sat for almost 2yrs for it's 302 to 351w swap. When I parked it the 302 was toast, but the AOD worked perfectly.
On my first test drive after the swap is when I found this problem. 1st 2nd and 3rd shifted completely normally, but to get it to shift from 3rd to 4rth took a loooooooooong time, and you had to let up off the gas some or it would rev up. But once the shift was complete, 4rth worked just fine. No slipping at all after the shift.
That was the only trip it maid like that.
Before it left the driveway again, I installed a transgo shift kit, and throughly checked all moving parts and passages on the valve body.
Installed a TCI "Super Overdrive Servo"
Deep TCI pan
External stacked plate cooler
external filter
And set the TV to be at max at WOT.
After these upgrades, the 1-2 and 2-3 shifts are exactly the way they should be with the mods. The 3-4 shift is perfect at or below 1/4 throttle.
Above 1/4 throttle and the 3-4 shift acts like neither 3rd or 4rth is engaged for a split second. The rpms rise, then it completes the shift and acts fine.
Understand, it does not slide into 4rth, it acts like it goes to neutral for just a split second during the shift. And 4rth has never slipped.
It has been this way for several thousand miles, with no change of any kind.
Any AOD buffs wont to enlighten me as to what the problem may be.
Deep TCI pan
external filter
