Did the 78/79 ever come with power windows?
9.3K views 23 replies 8 participants last post by  Hillbilly Heaven
#1 ·
Been looking to get my body and interior stuff together. I can’t find factory style door panels and swiches, never had it as option I guess? I thought it was just I always drove service trucks with an AM radio and no A/C LOL.
#2 ·
Yo 445,
We had a 78 Bronco with no AC, catalyticconverter, C6, etc ! Much easier to maintain
Here's the
1978 Bronco Dealer Brochure via Indybronco
Unfortunately, SM owner Dana has added ads that block info and diff for me to delete.
Here is the Ford 1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual via topsig (Ziggy) @
1979 Ford Bronco Wiring Manual pictures, videos, and sounds | SuperMotors.net
It shows Electrical component location, operation, troubleshooting, with wiring and vacuum diagrams, but DOESN'T show pw.
No pw shown in 1979 Bronco Brochure (partial) @ Early Bronco HQ is about 1966-77 Ford Broncos -- 1979 Bronco Sales Brochure
#3 ·
I'm pretty sure that wasn't an option for 78/79 in the Broncos or F-series. However! You could get cruise control and intermittent wipers!
My Bronco didn't have intermittent wipers, as it wasn't a common option people got, but I snagged the setup off a mid 80's truck and put it in. Works great!
If you manage to find a good aftermarket power window setup that would be nice, though I kinda like the ability to roll the windows up and down when I have the battery out or in case it dies, etc.
#4 ·
I like the idea of being able to operate the passenger side while driving is all otherwise I wouldn’t care. They make regulators that bolt in easy enough but swiches are limited to hot rod window crank switches that only operate one window. Guess a selector switch would work to toggle motors left and right on the driver side.
#5 ·
#6 ·
My 79 Camaro z28 had power windows. The switch was in the center console thingy.
Consider also finding a window motor from some other Ford and using a second rear window switch to roll it down.
#7 ·
The actuators are easy as pie, the kit comes with complete regulators, motors and mounting brackets. The switches are limited to hot rod switch panels or crank switches. The crank switch looks cool it is just limited on function like double click down all the way or L/R toggling. I am thinking install a selector switch that isn’t obvious, I am using a stock bench so console to mount the switches in a central location other than dash. Then I need to deal with the holes in the door panels too if I do not use the crank holes.
#9 · (Edited)
#14 ·
I got the LMC kit and ended up returning it. My opinion was it was very cheesy and cheap.
I ended up getting regulators and a switch kit from A - 1 electronics or something like that.
They were decent other then one switch was dead on arrival ( but they promptly replaced)
My only complaint I wish I could find better motors as the passenger one died only after a year or so .... also the driver side and passenger side motors are different.
#15 ·
If someone wanted power windows without the worries of replacement parts or cheesy parts of an aftermarket kit, then using OEM parts from LMC is the best idea.
All the OEM parts needed to do the conversion are available from LMC. Rather than grinding the slider to fit the 78-79 bottom rail, it maybe possible to replace the later slider with the earlier one.
#17 ·
But what would you do for replacement or repair parts, if you ever needed them? I think the OEM conversion is more proven, durable, and easy to find parts for than an aftermarket kit. Yes it requires a little bit of extra work, but nothing a typical owner couldn't handle.
