Well, seeing as how nobody has done a write-up on this, I will. :toothless
As everybody else has said, it is a direct swap. I got a booster and master cylinder for a '85 F-350. I ran some numbers and it appears that '83-'86 F-250's (any engine and 8600+ GVW) and '83-'86 F-350 (all engines) are the same. I looked for some used stuff, but ended up getting a good deal on new stuff.
Oh, and the reason for doing this is because my master cylinder was leaking internally under hard braking, causing a soft pedal and the brake light to come on. My full write-up is here.
Booster and master cylinder:
Cardone remanufactured booster #54-73355:
Raybestos new master cylinder #MC39445:
Remove the master cylinder:
Remove the booster:
Install the new booster:
The new booster is about 1" thicker:
Install the new master cylinder:
I bought an adapter fitting that everybody said was needed for the front brake line (the Bronco was supposed to be 3/16 and the F-350 1/4), but I didn't need it. The new master cylinder had a 3/16 front fitting, so that was fine. My rear line had a 5/16 fitting on it, so I cut that off and re-flared a 3/16 one on.
All done:
Because of the extra thickness of the new booster, I had to make a new bracket for my OBA oil separator; it was touching the end of the master cylinder.
After bleeding the brakes, I took her for a test drive. I still can't lock up the tires, but it does take less pedal pushing effort to stop the truck, and after wheeling today, I did notice the extra braking ability coming down rocks and hills.
This was a worth-while modification. :thumbup
Remove the booster:
All done:
