Headlight issue on my 96
2.4K views 4 replies 4 participants last post by  fordbronco1995
#1 ·
Hi all,
I am hoping you can help me diagnose and fix an issue with my 1996 Eddie Bauer.
Yesterday I tried to take it for a ride after dark and I found the headlights are not working. Parking lights work and high beams don't work. The high beam indicator on the dash is always lit. It worked fine last weekend....
Any ideas where to start?
#2 ·
Loose bulb connection first to look for. Look to see if your bulbs are good too. Next you just might need a new switch. Took mine out and it just literally went to pieces. Saw burnt connections and cracking on the pieces.
#3 · (Edited)
Yo Nubzilla,
Welcome and congratulations on having the Very Best Year Big Bronco known to men, women, children and canines!
Following by Ford in 1996 Bronco/F Series Workshop Manual, partial @ 1996 Bronco/F-Series Workshop Manual
Section 17-01: Lighting, Exterior
1996 F-150, F-250, F-350, F-Super Duty Motorhome and Bronco Workshop Manual​
DIAGNOSIS AND TESTING
  • Headlamps Inoperative
  • Circuitry open/shorted.
  • Damaged headlamp switch.
  • Blown fuse.
Pinpoint Tests — Headlamps
NOTE: Use Rotunda 73 Digital Multimeter 105-R0051 or equivalent when performing electrical pinpoint tests.
PINPOINT TEST A: HEADLAMPS INOPERATIVE
A1 CHECK SUPPLY VOLTAGE AT HEADLAMP SWITCH
  • Gain access to the headlamp switch connector.
  • Using a voltmeter connected to a known good ground, check for battery voltage at Pin B1 of headlamp switch.
  • Image
  • Pin Number​
    Circuit​
    Circuit Function​
    B1​
    38 (BK/O)​
    Power (Hot at All Times)​
    B2​
    195 (T/W)​
    I​
    294 (W/LB)​
    Dimmer Output to Fused Interior Lamp Feed​
    IGN​
    137 (Y/BK)​
    Power (Hot in ACC or RUN)​
    R​
    14 (BR)​
    Headlamp Switch to Tail Lamp and Side Marker Lamps​
    H​
    15 (R/Y)​
    Headlamp Dimmer Switch Feed Power (Hot in HEAD)​
    DN​
    484 (O/BK)​
    Radio Illumination Feed​
    D1​
    54 (LG/Y)​
    Interior Lamp Switch Feed Power (Hot at All Times)​
    D2​
    55 (BK/PK)​
    Dome Lamp Switch to Dome Lamp​
    A2 CHECK HEADLAMP FUSE
    • Using a Rotunda 73 Digital Multimeter, check output voltage at power distribution box fuse 19, 40A.
    Is battery voltage present?
    YesNo
    GO to A3.SERVICE fuse 19 feed wiring or REPLACE fuse 19. RESTORE vehicle. RETEST system.
    A3 CHECK CIRCUIT 38 (BK/O)
    • Using a voltmeter, check for battery voltage on Circuit 38 (BK/O) at fuse 19 and at headlamp switch.
    YesNo
    SERVICE Circuit 38 (BK/O) for a short to ground. RESTORE vehicle. RETEST system.REPLACE damaged power distribution box fuse 19. RESTORE vehicle. RETEST system.
    A4 CHECK HEADLAMP SWITCH OUTPUT
    • Actuate the headlamp switch to the HEAD position.
    • Using Rotunda 73 Digital Multimeter 105-R0051 or equivalent connected to a known good ground, check Pin H, Circuit 15 (R/Y) at headlamp switch for voltage.
YesNo
GO to A5.REPLACE damaged headlamp switch. RESTORE vehicle. RETEST system.
A5 CHECK HEADLAMP INPUT TO MULTI-FUNCTION SWITCH
  • Headlamp switch still in the HEAD position.
  • Gain access to the multi-function switch connector.
  • Using Rotunda 73 Digital Multimeter connected to a known good ground, check Pin C2-2, Circuit 15 (R/Y) at multi-function switch.
  • Multi-Function Switch Connector
    Pin Number​
    Circuit​
    Circuit Function​
    1​
    589 (O)​
    Windshield Wiper Intermittent Governor Ground​
    2​
    15 (R/Y)​
    Headlamp Dimmer Switch Feed (High/Low Beam Selection)​
    3​
    13 (R/BK)​
    Low Beams​
    4​
    993 (BR/W)​
    Intermittent Governor to Windshield Wiper Switch​
    5​
    12 (LG/BK)​
    High Beams​
    6​
    590 (DB/W)​
    7​
    196
    (DB/O)​
    Flash-to-Pass Power Feed to High Beams​
    YesNo
    GO to A6.SERVICE Circuit 15 (R/Y) for an open circuit. RESTORE vehicle. RETEST system.
    A6 CHECK MULTI-FUNCTION SWITCH LOW BEAM
  • Headlamps in LO beam position.
  • Rotunda 73 Digital Multimeter still connected to a known good ground, check Pin C2-3, Circuit 13 (R/BK) at multi-function switch connector for battery voltage.
YesNo
GO to A7.REPLACE damaged multi-function switch. RESTORE vehicle. RETEST system.
A7 CHECK SUPPLY CIRCUIT TO HEADLAMP SWITCH
  • Using Rotunda 73 Digital Multimeter connected to a known good ground, check Circuit 38 (BK/O) at output side of 30A fuse 3 in power distribution box.
YesNo
GO to A8.SERVICE fuse 3 feed wiring or REPLACE fuse 3. RESTORE vehicle. RETEST system.
A8 CHECK CIRCUIT 196 (DB/O) FOR OPEN
  • Using a Rotunda 73 Digital Multimeter 105-R0051 or equivalent, check for battery voltage on Circuit 196 (DB/O) at multi-function switch connector Pin C2-7.
YesNo
GO to A9.SERVICE open circuit in Circuit 196 (DB/O). RESTORE vehicle. RETEST system.
A9 CHECK MULTI-FUNCTION SWITCH HIGH BEAM
  • Headlamps in HI beam position.
  • Rotunda 73 Digital Multimeter 105-R0051 or equivalent still connected to a known good ground, check Pin C2-5, Circuit 12 (LG/BK) at multi-function switch connector for battery voltage.
YesNo
GO to A10.REPLACE damaged multi-function switch. RESTORE vehicle. RETEST system.
A10 CHECK SUPPLY TO SUSPECT HEADLAMP
  • Gain access to the suspect headlamp connector. Disconnect the suspect headlamp connector.
  • Actuate headlamp switch to the HEAD position.
  • Using Rotunda 73 Digital Multimeter connected to a known good ground, connect other end to Circuit 13 (R/BK) for low beam test and Circuit 12 (LB/BK) for high beam test. Check for voltage with multi-function switch in LO beam or HI beam position.
YesNo
GO to A11.SERVICE Circuit 13 (R/BK) or Circuit 12 (LG/BK) for open circuit. RESTORE vehicle. RETEST system.
A11 CHECK SUSPECT HEADLAMP GROUND
  • Using Rotunda 73 Digital Multimeter 105-R0051 or equivalent connected to a known good ground, connect second lead to Circuit 57 (BK) at headlamp connector.
  • Measure resistance.
Is resistance 5 ohms or less?
YesNo
REPLACE damaged headlamp bulb. RESTORE vehicle. RETEST system.SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system.
PINPOINT TEST B: HEADLAMPS ON CONTINUOUSLY
B1 CHECK HEADLAMP SWITCH
  • With headlamp switch in the OFF position, use Rotunda 73 Digital Multimeter 105-R0051 or equivalent to check for voltage at Pin H of the headlamp switch.
Is battery voltage present at Pin H?
YesNo
REPLACE headlamp switch. RESTORE vehicle. RETEST system.GO to B2.
B2 CHECK MULTI-FUNCTION SWITCH
  • With headlamp switch in the OFF position, check for voltage at Circuit 12 (LG/BK) and Circuit 13 (R/BK) on the multi-function switch.
YesNo
REPLACE multi-function switch. RESTORE vehicle. RETEST system.GO to B1.
PINPOINT TEST C: HIGH BEAMS OR LOW BEAMS INOPERATIVE
C1 CHECK HEADLAMP SWITCH
  • Perform the headlamp switch component test. Refer to Component Tests in this section.
Did the headlamp switch test OK?
YesNo
GO to C2 for high beam failure. GO to C4 for low beam failure.REPLACE headlamp switch. RETEST system.
C2 HIGH BEAMS INOPERATIVE
  • With headlamp switch in the OFF position, use Rotunda 73 Digital Multimeter 105-R0051 or equivalent to check Circuit 12 (LG/BK) at the left and the right headlamp connector to Circuit 12 (LG/BK) at the multi-function switch.
Is continuity present in Circuit 12 (LG/BK)?
YesNo
GO to C3.REPAIR open in Circuit 12 (LG/BK). RESTORE vehicle. RETEST system.
C3 CHECK CIRCUIT 57 (BK)
  • With headlamp switch in the OFF position, use Rotunda 73 Digital Multimeter 105-R0051 or equivalent to check Circuit 57 (BK) from ground to the headlamp connector.
Is continuity present in Circuit 57 (BK)?
YesNo
REPLACE headlamp bulb. RESTORE vehicle. RETEST system.REPAIR ground circuit. RESTORE vehicle RETEST system.
C4 LOW BEAMS INOPERATIVE
  • With headlamp switch in the OFF position, use Rotunda 73 Digital Multimeter 105-R0051 or equivalent to check Circuit 13 (R/BK) at the left and the right headlamp connector to Circuit 13 (R/BK) at the multi-function switch.
Is continuity present?
YesNo
GO to C5.REPAIR open in Circuit 13 (R/BK). RESTORE vehicle. RETEST system.
C5 CHECK GROUND CIRCUIT 57 (BK)
  • With headlamp switch in OFF position, use Rotunda 73 Digital Multimeter 105-R0051 or equivalent to check Circuit 57 (BK) from the ground to the headlamp connector.
YesNo
REPLACE headlamp bulb. RESTORE vehicle. RETEST system.REPAIR ground circuit. RESTORE vehicle. RETEST system.
PINPOINT TEST D: ONE HIGH BEAM OR ONE LOW BEAM HEADLAMP INOPERATIVE
D1 CHECK FOR POWER TO INOPERATIVE HEADLAMP
  • Disconnect connector to inoperative headlamp.
  • Headlamp switch in the HEAD position.
  • For high beams inoperative:
    • High beams on.
    • Measure the voltage on Circuit 12 (LG/BK) at the headlamp connector.
  • For low beams inoperative:
    • Low beams on.
    • Measure the voltage on Circuit 13 (R/BK) at the headlamp connector.
Is the voltage greater than 10 volts?
YesNo
REPLACE the headlamp bulb. RESTORE vehicle. RETEST system.SERVICE Circuit 12 (LG/BK) or Circuit 13 (R/BK) for open in the high beams or low beams. RESTORE vehicle. RETEST system.
PINPOINT TEST E: FLASH-TO-PASS INOPERATIVE
E1 FUSE CHECK
  • Check power distribution box fuse 3.
Is the fuse blown?
YesNo
REPLACE fuse 3. GO to E2.GO to E2.
E2 CHECK CIRCUIT 38 (BK/O)
  • Remove fuse 3.
  • Using Rotunda 73 Digital Multimeter 105-R0051 or equivalent, check continuity on Circuit 38 (BK/O) from power distribution box to multi-function switch connector at Circuit 196 (DB/O).
YesNo
GO to E3.SERVICE open circuit between power distribution box and multi-function switch. REPLACE fuse. RESTORE vehicle. RETEST system.
E3 FLASH-TO-PASS SWITCH CHECK
  • Remove fuse 3.
  • With the flash-to-pass switch held in the ON position, use Rotunda 73 Digital Multimeter 105-R0051 or equivalent to measure continuity from Circuit 196 (DB/O) at the multi-function switch to Circuit 12 (LG/BK) of the multi-function switch.
Is continuity present through the multi-function switch?
YesNo
Switch OK. GO to C2.REPLACE multi-function switch. RESTORE vehicle. RETEST system.
â—Ź
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 71
... have VIN ready.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ https://www.ford.com/cmslibs/conten...m/brand_ford/en_us/brand/suvs-crossovers/bronco/pdf/96_Ford_Bronco_Brochure.pdf
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
For any more Bronco questions or to chat about it's planned modifications, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (50 posts required to participate due to scammers who preyed on our members).94
Baba Looey's Favorite FSB Links (lots and lots of tech links), includes "how do I get the tailgate glass to...", etc.
Our Sites' FAQs, includes for example:
How To Save (Bookmark) Threads Or Posts
How To Search The Site
What is the Difference Between the Showcase and Gallery?
ETC.
Try to find time to participate and vote in our current Full-Size of the Year Contest & in the next Full-Size of the Month Contest @ Voting
You will get ideas by those competing. Prizes are awarded to the winner; a full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted; and a years worth of premium FSB membership.
Al
