Yes I have attempted the search function, I haven't found an answer.
Ok, I just purchased my 2nd bronco Friday. It's a 1996 Eddie Bauer with the 351. This bronco is the closest to stock I've seen. Still has the factory exhaust and radio! Anyway, my issue is when I bought it the only issue was the original auto dimming rear view mirror was missing. The plug was also broken off so I had open ended wires hanging and the temp/compass was off. I assumed it was due to the missing mirror. After some research today I think I have found out that those wires were just power for the auto dimming rear view mirror. So, why is my temp/compass dead?
I pulled it down and checked power using a reference I found somewhere, supermotors something? Anyway, I do have 12v between the black and white wire at the connector when the key is on. So is the temp/compass just bad? Can you buy a new or aftermarket one? Can they be repaired? Thanks in advance
